why pin the balancer?
Old Aug 27, 2009 | 09:49 PM
Taubr Unit's Avatar
Default why pin the balancer?
So if the balancer already has a keyway on it why go the extra mile and pin it also? I have the tool coming already but seems over kill no? Does the key break on them or what? And how would they spin off without it being pinned?
Old Aug 27, 2009 | 11:01 PM
Monte LS....1's Avatar
LS has no key way
Old Aug 27, 2009 | 11:24 PM
Chrome355z's Avatar
Originally Posted by Monte LS....1
LS has no key way
Old Aug 28, 2009 | 12:18 AM
JFM-jr's Avatar
Yep the snout of the LS crank is not key'd . . . .
Old Aug 28, 2009 | 12:36 AM
98RedBird's Avatar
What's your setup? I see that you have a 94, but it also says that you are running a procharged 6.0L. As the others have said, the LS's do not have a keyed crank, hence the reason that you would need to pin it in your situation, which I'm assuming is procharged.
Old Aug 28, 2009 | 02:52 AM
Chris@Straightline's Avatar
the keyway on the ls series motor is just for the timing gear and oil pump drive, unless the crank in the motor you're running has been machined for a longer keyway to also locate an aftermarket crank pulley
