truck MAF questions!
Old Aug 29, 2009 | 11:56 AM
foreverzero's Avatar
Default truck MAF questions!
These questions are for those who have swapped to the 85mm truck MAF: Where do I get the connector adapter for the MAF? Also I was planning on getting the FTP 98mm lid... i was wondering because i have an SS, will it rub or crack the lid?
Old Aug 29, 2009 | 09:03 PM
1999BlueTA's Avatar
Here's a link to the one I bought http://www.lsxtune.com/shop/product_...oducts_id/1026 but I bought this one because i'm using a regular MTI lid if you going to use the FTP lid I would suggest getting this one http://www.lsxtune.com/shop/product_...roducts_id/927 it lets you use the IAT that's built into the 85mm MAF instead of drilling a hole into your FTP lid to use the factory IAT. I'm unsure about the rubing issue on the FTP but I think a few Camaro owners have rubbing issues but then again i'm unsure so unless some Camaro owner's who have these lids chime in a search might be your best bet.
Old Aug 30, 2009 | 01:16 AM
Frost's Avatar
I see you are tuned in your sig... it will drastically alter your WOT AFR as well as the amount of work your trims will be doing until you re-tune.
Old Aug 30, 2009 | 02:31 AM
Yeah, Im planning on doing a retune after anyway. Ive added the truck coils, udp, and a few other things since the last tune.
