solid mounts with bmr k-member
Old Aug 31, 2009 | 11:34 PM
dudeman's Avatar
Default solid mounts with bmr k-member
i have a bmr turbo k-member and i need some solid mounts. anyone know who makes solid mounts that will work with this k-member???
Old Sep 1, 2009 | 03:52 PM
dudeman's Avatar
i just found out there is not one. anyone ever made solid mounts out of the stock ones. pics?
Old Sep 1, 2009 | 03:57 PM
Wesmanw02's Avatar
Any particular reason you're looking for solid mounts??
Poly mounts are plenty stiff for just about any application, they almost as stiff as solid mounts only without the annoying vibrations.
Old Sep 1, 2009 | 04:58 PM
dudeman's Avatar
its turbo'd and the down pipe goes next to the motor mount. its just a heat issue.
Old Sep 1, 2009 | 06:24 PM
Wesmanw02's Avatar
Polys are pretty resistant to heat as well...not sure as to what temp, but they can probably sustain some pretty serious heat, even from a downpipe.
Old Sep 1, 2009 | 08:04 PM
dudeman's Avatar
good to know. they are only like 60 bucks!
