ory question
Old Sep 4, 2009 | 08:34 PM
camaross00black's Avatar
Question ory question
i have a 2000 camaro ss with borla ehaust opened up all the way and it is just not loud enough, i was thinking of putting a ory pipe to the stock manifolds, i would do the whole header thing but these cars are a pita to install and pretty pricey too. if i did something like this would you need to get it tuned just for something like this. also would it make it louder. and what is a good brand to get that bolts up good. thanks for the help.
Old Sep 5, 2009 | 07:19 AM
BluShadowSS's Avatar
if you want it loud headers are a must and they are really not that hard if you have some help.
remember you get what you pay for with headers as far as fit and finish.
pacesetters < arh or kooks
you dont have to get tuned, but you will have a ses light that can be turned off by a tuner.
Old Sep 5, 2009 | 07:26 AM
StangeatinZ28's Avatar
if you want to do an offroad y with the stock manifolds (why i dont know) then bassani makes them
Old Sep 5, 2009 | 07:57 AM
if you dont get it tuned will it make it not run as good, hard on the motor with no tune.
Old Sep 5, 2009 | 07:58 AM
Red99TA's Avatar
As mentioned headers really aren't that hard. The hardest part is just getting the car jacked up high enough to angle them up from the bottom. Or if you have access to a lift then it's really easy IMO. As for brand I ran pacesetters for years with no problems. Sure they're not stainless but then again you're not going to be driving through rainstorms every day either...a little bit of surface rust down near the collectors is all I ever saw.
Old Sep 5, 2009 | 08:50 AM
teke184's Avatar
i had the bassani and the fit was horrible. clearances with the frame were too small and caused banging, the shop needed to cut one side to shorten it so it didn't hang TOO low.
sound was great, didn't notice any gain in power.
when i did my LT headers.....alone, first ever header install, and in my driveway with jackstands.....it took me 10hrs.
Old Sep 5, 2009 | 08:59 AM
It wont hurt your motor you will simply run a little rich is all.
