power steering pump
Old Sep 7, 2009 | 08:25 PM
Justus67's Avatar
Default power steering pump
when taking off the power steering pump do you pull the pulley or un screw it from the center?
Old Sep 7, 2009 | 08:31 PM
NemeSS's Avatar
supposed to pull the pulley if have the tool,
or u can use a 15mm open end wrench to unscrew the bolts. wont ever get a socket in there with pulley still on
Old Sep 7, 2009 | 09:58 PM
massls1guy's Avatar
When I swapped heads I removed the PS pump from the head without touching the pulley. Ls1howto has some instructions:
http://www.ls1howto.com/index.php?article=2
