will these headgaskets work
Old Sep 11, 2009 | 08:41 AM
overkill-lt1's Avatar
Default will these headgaskets work
i purchased a set of gm head gaskets for an 02 z06. will these work on a 99 alum block with either patriot or texas speed ls 6 heads. just need to make sure thanks
Old Sep 11, 2009 | 09:08 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
yes they will. it is not the block you have to worry about. it is the head itself. the ls6 head will not (well should not) have the problem that would need the graphite gasket.
