Gaguge Panel Acting Wierd
Old Sep 24, 2009 | 07:48 AM
groundscraper's Avatar
Default Gaguge Panel Acting Wierd
Hopefully I'm in the right section here.
Ever since I changed the oil on my '99 camaro (I reset the oil), my gauges have been acting wierd (so I think). Every time I start the car (only after it has been sitting there for a while) the trip resets to 0 and all the gauge needles move to the max, then back down, then they go to the appropriate spot (I don't think they did that before). I didn't think of if much until last night when I went to the pharmacy. I turned on the car and the "Service Vehicle", "BRAKE", and "ABS INOP" lights came on. I truned off the car and turned it back on, they they were gone. This morning when I turned on the car to come to work, the "Service Vehicle" light turned on. I turned off the car and back on and it was gone. The car seems to be running fine and it has no problems starting or anything. I am going to check the battery and the terminals to make sure those are in good condition and tight when I get home. Could it be something else? Has anybody experienced something similar?
Thanks,
Albert
Old Sep 24, 2009 | 07:56 AM
THE BIG KAHOONA's Avatar
No not yet but that is just something else to worry about now . Try disconnecting the battery over night . Kinda like a re-boot of the system .
Old Sep 24, 2009 | 02:08 PM
Weezzer's Avatar
Does the odometer trip milage reset as well?
Yer battery is going out.
Old Sep 24, 2009 | 02:18 PM
1Loudz28's Avatar
i have a 99 and i had the same problem. turns out 99s had a feature that causes to gauges to reset when theres a weak battery. i replaced mine and it stopped doing it
Old Sep 24, 2009 | 03:12 PM
2001NBMZ28's Avatar
Yeah have the battery load tested. There is a TSB to replace the gauge cluster in the '99's but a good battery/connections makes it go away.
