gm part number
Old Oct 2, 2009 | 07:23 AM
ssdungeon's Avatar
Default gm part number
For a c5
oil pressure sending unit. I have found that the c5 uses a three wire. No one seems to have that part number listed.
Old Oct 2, 2009 | 09:18 AM
99monguse's Avatar
1997-2003 C5 oil pressure sensor right by the crankshaft position sensor(on the block), is part number 12561211. This sensor has a black three-way connector on it.
Old Oct 2, 2009 | 09:54 AM
MM98's Avatar
Negative, the # you listed is a cam sensor ... The oil pressure sensor is by the cam position sensor behind the intake.. The part # is 12616646.
Old Oct 2, 2009 | 10:13 AM
ssdungeon's Avatar
Default thanks
Tis what I needed. SMan I have googled so much that I reached the END OF THE INTERNET looking for that part number.
Sheesh!!
Old Oct 2, 2009 | 12:58 PM
99monguse's Avatar
Youre right I listed the wrong number I meant the pressure sensor which is by the cam sensor and the number I listed was the cam not the oil sender, duh! Sorry about that! I have the screen right in front of me and I listed the wrong number.
99monguse's Avatar
I have the GM parts catalog!
