question on poly mounts
Old Oct 5, 2009 | 05:13 PM
Taubr Unit's Avatar
Default question on poly mounts
Iv looked but didnt find what i needed.....
on the poly mount, the insert is off-set to one side. my question is..what side (front or back) do they sit in the clam shell? When i got them off the member on here they were aranged the same on both sides. Seems like the motor would want to sit in the k-member crooked. AKA the insert on one side is more foward and on the opposite side more backwards. How should they go??
Old Oct 5, 2009 | 06:28 PM
6.0 silverado's Avatar
I looks like you got two mounts for the same side. It has happened before. I think I saw a thread on it somewhere...
Old Oct 5, 2009 | 06:48 PM
Taubr Unit's Avatar
i dont think there side specific. I can flip it around and mount it the other way, just need to know if the long or short side is the leading side.
Old Oct 5, 2009 | 06:49 PM
you can't flip them around unless you cut the tabs off
I'll go look at mine right quick...
EDIT:
It looks like the short side was leading. It's tough for me to see though and I can't really put my car in the air right now. Maybe some else can chime in...
Old Oct 5, 2009 | 06:51 PM
Taubr Unit's Avatar
think were talking about different things. Im talking about the poly inserts, i can turn them eaither way. The steel shells are left and right, just need to know the placement of the poly inserts.
Old Oct 5, 2009 | 07:01 PM
If you put them on, as they are in the pictures, one side will have the short forward and one side will have the long forward. You would have to flip the mount over in the clam shell to get the same side forward and means the tabs would be on the bottom (that is a no no).
I edited my previous post as well.
Old Oct 5, 2009 | 07:04 PM
Taubr Unit's Avatar
i played with them for a while seein how they fit etc. I know they are the right shells, they fit right and trust the member i bought them off of on here, took them right off his car. Just think the inserts were put in wrong. Im assuming they should be symetricial from one side to another (talking about the inserts).
Old Oct 5, 2009 | 07:06 PM
your clam shells are not side specific, but the mounts are. It looks like you have two passenger side mounts.
Edit:
To be clear, the inserts are side specific.
And now that I think about it, I don't think I paid attention to which side (long or short) was in the front when I re-assembled it. haha.
 Michael S. Palmer
Old Oct 5, 2009 | 07:19 PM
demonpixel's Avatar
This is correct. One side will have the short part forward, and one will have the long part forward.
These are how mine are installed:
Driver side:
Passenger side:
Old Oct 5, 2009 | 07:24 PM
donman's Avatar
Hope this helps..
Well I just saw the post above mine and he has better pictures in there..
Drivers side
Passenger Side
Drivers
Passenger
Don
Old Oct 5, 2009 | 07:52 PM
Taubr Unit's Avatar
no **** huh?!? Well when the paint dries ill put um just like that. Weird they go in different, seems like the motor would want to sit crooked, Guess not, thanks guys!
Old Oct 7, 2009 | 09:42 AM
Z28M6TT's Avatar
Originally Posted by donman
Passenger Side
make sure u realize the mount in this pic is upside-down...
the 3 hollow rivets go up top, the two solid ones are on the bottom (before you drill them out obviously). if you already drilled em out the top of the outer shell is the wider part with the extra "wings". they are the same on both sides
and someone correct me if im wrong (seriously)... but i believe the mounts on the k-member are in line with each other, but the mounts on the block are offset since the cylinder banks are offset. thats why the inserts are offset, however interchangeable side to side.
Old Oct 9, 2009 | 05:19 PM
Taubr Unit's Avatar
well i dunno bout ls1s but my iron 6.0 the mounts are the same on each side, they are in line with each other and so are the mounts on my k-member. Everything is perpindicular to each other, thats why this **** was throwin me for a loop!
Old Oct 9, 2009 | 05:51 PM
kenp's Avatar
The way they were originally is correct.
Old Oct 9, 2009 | 06:37 PM
01ssreda4's Avatar
demonpixel is correct. One side has a long side facing forward, the other has a short. I know it denies all logic but thats just how it is. You can insert the polys themselves in either clamshell and it will work.
