want to add cats to my ory
Old Oct 7, 2009 | 07:11 PM
mondols1's Avatar
Default want to add cats to my ory
like the title says i want to add cats to my ory. i measured the circumference of my y at the 3 bolt flange and down and it was 9.75 inches which if i remember right i need to divide that by 3.142 (pi) to come up with a 3.10 inch diameter. so the .10 must account for the material thickness? so i believe i need a cat with 3 inch inlet and outlet, does that sound like the right size? also are there any cats that are short like the magnaflows that are a good low cost alternative?
Old Oct 7, 2009 | 11:08 PM
hitmanws6's Avatar
google thunderbolt metallic cats. they are 110 plus shipping
Old Oct 7, 2009 | 11:18 PM
tspence45's Avatar
Metallic spun Magnaflows are only $95+shipping through Summit.
Old Oct 7, 2009 | 11:22 PM
hlaalu's Avatar
oh they are cheaper than that unless you mean for both of them.
http://www.performance-curve.com/ind...OD&ProdID=1181
I had these ones on a y-pipe i made, they passed smog just fine too
Old Oct 7, 2009 | 11:32 PM
hitmanws6's Avatar
exactly what i was referring to
Old Oct 7, 2009 | 11:41 PM
hlaalu's Avatar
yea these cats are great, you can cut off the ends so they fit pretty much wherever you want them.
Old Oct 7, 2009 | 11:46 PM
tspence45's Avatar
Damn. That is a good price. I'm thinking about buying some to throw on my H-pipe I'm having fabbed, just to tame it down a little, and make sure there's no rasp at all.
Old Oct 8, 2009 | 06:48 PM
mondols1's Avatar
i'm going with those just because of the price. i just hope they flow good and dont choke things off.
Old Oct 10, 2009 | 11:15 AM
jimmypop13's Avatar
I wouldn't worry about it cutting down much on airflow. I have the magnaflow version on my 3" x-pipe and the setup is still somewhat raspy.
