Going to a 100 mm MAF from a 85 mm MAF on a stroker?
Old Oct 11, 2009 | 08:50 AM
Bill00Formula's Avatar
Default Going to a 100 mm MAF from a 85 mm MAF on a stroker?
Now that there are so many strokers, is there a definative answer. I did a search and there seemed to be a lot of opinions rather than facts.
I have a LS7 based 427 w/ tf 235s. It has an slp 85 MAF w/ the resistor removed (I always wondered if that could have damaged the MAF). I should have gone w/ a gm part.
I know it wouldn't be a huge increase but every little bit helps. Thanks
Old Oct 11, 2009 | 09:28 AM
jimmypop13's Avatar
Make sure your whole intake tract is 100mm or your not gonna notice a difference so you would need the Fast Toys 108mm lid to fit the maf into, a 102mm Fast/TB setup and custom 4" tubing to connect it all. If you have a 90mm setup, it'd probably be best to just look for a used unmolested 85mm maf on here from a truck or a z06
Old Oct 11, 2009 | 02:05 PM
Bader-X's Avatar
he means a fast 92 with a tb choice of 92/95/96 as your heads are ls1 based not ls3/7
just correcting as I don`t have an advice on this field
Old Oct 11, 2009 | 03:31 PM
Hamrdown's Avatar
I know the 100mm mafs are a pain to tune. it can be done but even TSP says it takes an experienced tuner to tune one and that it can be a pain. Personally I would do away with the maf and just go speed density.
Old Oct 11, 2009 | 03:57 PM
Frost's Avatar
The 100 MM MAFs tune like all of the rest of them when you have them in front of you...
Old Oct 12, 2009 | 08:02 AM
The Dragon's Avatar
Thumbs up
Yup
Old Oct 12, 2009 | 02:15 PM
jimmypop13's Avatar
Oh so you aren't using LS7 based heads? Then yeah, you'd need a FAST 96mm intake and throttle body to take advantage of the 100mm maf. I think Vengence Racing is the only place converting 92mm FAST's into 96mm
