flowmaster merge question
Old Oct 30, 2009 | 12:23 PM
therobman's Avatar
Default flowmaster merge question
im about to order one from summit i dont really know what size to get i have a 3" pacesetter y and a 3" catback also will i need any other couplers or anything to make it fit or can i simply cut it out and weld it in???
thanks
Old Oct 30, 2009 | 02:32 PM
therobman's Avatar
Old Oct 30, 2009 | 02:37 PM
tim99ws6's Avatar
Depends on what your Y-merge looks like right now, but I think the one i put one on did require a extra 90* elbow. It's been a few years though, so bear with me!
Old Oct 30, 2009 | 03:56 PM
therobman's Avatar
thanks anybody else have some insite
Old Oct 31, 2009 | 12:53 PM
therobman's Avatar
Old Oct 31, 2009 | 01:44 PM
Damian's Avatar
LSX Mechanic
This is what it looks like:
And a quick google search...
http://cgi.ebay.com/ebaymotors/Flowm...01810006r18836
You will need the 3" going into a 3.5".
Old Oct 31, 2009 | 02:43 PM
1redta's Avatar
I used the 3" in y to 4" merge with a dynomax race magmun and piece of 4" pipe ro the axle. after that I used a 4" to 3" adapter to go back to the 3" catback I had in place. There is a huge thread here that PatG started about this.
Old Oct 31, 2009 | 02:52 PM
LS1ROPER's Avatar
I have 3" y pipe along with 3" I pipe I ordered the 3x3.5 Flowmaster Merger worked with no coupler or anything just make sure you go to a good Exhaust Shop fitment is important not much room as Im sure you know!
Old Oct 31, 2009 | 03:05 PM
therobman's Avatar
thanks did you have a pacesetter y?
Old Nov 1, 2009 | 12:07 AM
ScrapinBye's Avatar
I have a pacesetter ORY with the FM merge welded in. I ordred the 3" inlet/3.5" outlet FM merge. The exhaust shop was able to cut and chop and put in a reducer without me suppling anything but the merge itself. Any decent exhaust shop should be able to do this with no problem.
Old Nov 1, 2009 | 01:08 AM
therobman's Avatar
me and my dad are doing it he has his own shop he knows what hes doing but heres the pacesetter y it looks tight when i cut it off looks like ill need two 45 degree bends
Old Nov 1, 2009 | 01:13 AM
jetlag's Avatar
therobman, I also thought two 45* pieces would work...it did not..
Here is my post about using a Pacesetter Ypipe
https://ls1tech.com/forums/12018378-post4.html
Old Nov 1, 2009 | 02:13 PM
therobman's Avatar
thanks thats what i was looking for looks like it should be fun lol
Old Nov 1, 2009 | 02:32 PM
KurtRardin's Avatar
Veteran: Marine Corps
I've got some more pics of the same setup in my sig. It made a nice difference in the top end. I bet your setup sounds awesome jetlag!
Old Nov 1, 2009 | 10:28 PM
jetlag's Avatar
It definitely helped with the rasp! It is pretty much all gone now and sounds a ton better.
The Pacesetter "merge" is pathetic.
Old Nov 2, 2009 | 12:01 AM
therobman's Avatar
thats what i plan to kill the rasp
Old Nov 2, 2009 | 06:59 AM
KurtRardin's Avatar
I wouldn't plan on it killing all the rasp unless you dump it like jetlag. Yes the merges that most Y pipes use don't do anything to help it I still feel like its the single 3" pipe going over the axle that rasps it up. My hooker exhaust is a little raspy still. You know, come to think of it, I seem to remember a member here talking about how his 4" mufflex with magnaflow muffler was raspy too.
The merge will help a lot with the rasp. Dumping the exhaust helps to hide it too.
Old Nov 4, 2009 | 01:47 PM
therobman's Avatar
as long as the merge cuts down the rasp a little i just got it in the mail its a very nice piece now i see why people say the pacesetter merge is terrible hahaha ill post up results after i install it
