milling ls6 heads?
Old Nov 3, 2009 | 10:42 AM
00sscamaro4's Avatar
Thumbs up milling ls6 heads?
i have a set of zo6 ls6 heads im putting on my ls1 and i need to get them milled or touched up would milling raise the compression if so how much
Old Nov 3, 2009 | 11:24 AM
Jon@Texas-Speed's Avatar
Yes it will raise the compression. How much depends on how much you are milling. If you are just cleaning up the deck surface with a .002-.003" mill, it won't change the compression enough to worry about it. Let me know if you are milling more and how much and we can calculate the compression change for you. Remember you are already raising the compression putting the LS6 heads on since they are 2-3cc smaller than the LS1 heads. Your compression should be at 10.5:1 with the LS6 heads before milling.
Jon
Old Nov 3, 2009 | 11:27 AM
Post
i bent the valves an messed the chamber i guess you would call where the valves are pretty good so idk
