Throttle Sticking, Need Some Suggestions please
Old Nov 5, 2009 | 10:25 PM
double-you-S6's Avatar
Default Throttle Sticking, Need Some Suggestions please
Not sure if im posting in the right section, but here it is...
I have a 99 ws6 that my dad and i just got done with a complete engine swap on. I took it out tonight to see if everything was holding together alright, and noticed that when i come to a stop and am about to take off again, it seems like the throttle gets stuck when its all the way open and i almost have to give it a little kick to get it loose again. Any suggestions as to what could be wrong?
Old Nov 5, 2009 | 11:33 PM
Hamrdown's Avatar
you probably need to adjust the throttle cable if its got traction control or there should be a small set screw on the bump stop where your tb cam bracket hits that you can adjust to open the blade a little more. if its not down shifting like it should then thats a tell tale sign the cable needs to be tigtened. Otherwise adjust the set screw and you should be golden.
