waterpump on the way out? help!
ok car has been running hoter than normal even on the hwy i have a 180 t-stat thats new and i also cleaned out the radiator and condesor and got out all the little leafs and crap out of it when i put the new t-stat in(car with oem stat was running hot with the ac on so i cleaned it all out and put in the new 180 statmy cars a 98 so its suposed to have the more true temp gauge and with the oem stat it would stay right at the 1/4 mark between the 160 and 210 mark and with the 180 stat it stays between the 1/4 mark and the 160.
thing is if i get stuck in traffic or just going about 50-60-mph it will start to get warmer like a little past the 1/4 mark and even if i get to speed up it wont go back down.
the fans are set lower so is my wp on its way out? its not leaking or any thing but i had a car do this before and it would slowly get warmer and warmer till i swaped the pump then it was fine.
