Pulley removal...
Old Nov 24, 2009 | 08:01 PM
Paul57's Avatar
Default Pulley removal...
OK...let me start out with...don't crucify the LS1 rookie .
Has anyone ever used an impact to remove the harmonic balancer/pulley bolt?
Also, I just took a real quick look at the water pump pulley so maybe I missed something...what does it take to get the pulley off there, if I ever need to??
Old Nov 24, 2009 | 08:05 PM
jsteele90's Avatar
its perfectly fine to remove the bolt with an impact, done it several times.
Old Nov 24, 2009 | 09:49 PM
tom falco's Avatar
The impact is fine and probably the only way to remove the bolt. The WP pulley does not have to come off. The WP comes with a pulley installed with the UP dated WP.
Old Nov 26, 2009 | 01:11 AM
sscamaro1384's Avatar
yeah pulling the crank pulley is way easier with the impact versus with hand tools.
Old Nov 30, 2009 | 12:30 PM
rjensen's Avatar
i have read that is the only bolt on the engine that you are ok with using an impact
