please help with MAF
Old Dec 6, 2009 | 05:34 PM
getsum27's Avatar
Default please help with MAF
my stock maf sensor is bad.........
its making the car go way lean and on the hp tuners scanner it shows that its not flowing near what it is....
i borrowed another stock maf off another car and the car runs great again!
the car has k&n, ported tb, ls6 intake, LT's true duals..........
the car will have a cam by spring....... maybe heads/cam
should i just buy another stock maf or upgrade to the z06 maf?
i know there will be tuning required for that.
Also, if i did buy another stock one, would an oreilly's stock maf be good enough or would i need to go with a gm part
oreilly's reman stock is $140
what do you guys think?
please help i need to order one in the next day or 2
Old Dec 6, 2009 | 05:48 PM
BaddBird's Avatar
You cant go wrong going with oe GM.
Old Dec 6, 2009 | 05:49 PM
99Bluz28's Avatar
Did you already try just cleaning the MAFS with some mafs cleaner?
Get a new Gm unit for $154
Gmpartsdirect.com
Old Dec 6, 2009 | 05:54 PM
getsum27's Avatar
yes i tried cleaning it.......... seemed to help a little of the low rpm problem but not enough.......... it was a huge difference when i swapped the other stock maf from the other car
Old Dec 6, 2009 | 06:00 PM
99Bluz28's Avatar
pm sent.
Old Dec 6, 2009 | 06:02 PM
BaddBird's Avatar
I don't know if this is what happen to yours or not, but I have seen allot of people over oiling the k&n causing maf failures.
Old Dec 6, 2009 | 06:09 PM
getsum27's Avatar
it does have a k&n but i dont think it was filter oil on it............. just looked like crap from years of use
Old Dec 6, 2009 | 06:10 PM
69LT1Bird's Avatar
Super cheap on ebay or just go to a local salvage yard and get one for about $30-40.00
 Michael S. Palmer
Old Dec 6, 2009 | 06:19 PM
getsum27's Avatar
so are all you guys saying go with a stock maf
you all are against the z06 85mm?
Old Dec 6, 2009 | 06:23 PM
69LT1Bird's Avatar
Your current setup doesn't need it. Why tune it for just a MAF change. Just get it running and in the spring, when you say you want to do a cam and heads, put a bigger MAF in and tune it all then.
Old Dec 6, 2009 | 06:27 PM
getsum27's Avatar
i have the hp tuners program
thats the only reason i would be willing to change
Old Dec 6, 2009 | 07:19 PM
PUNISHER TA's Avatar
Id just get a used replacement for now, no need to get a new one,
There are plenty for sale.
I have a thunder racing ported one laying around, if you want to upgrade.
The Z06 one isnt worth it, you have to splice in new connectors, it just include the IAT sensor.
Old Dec 7, 2009 | 11:36 AM
getsum27's Avatar
ok so i have a buddy that works at an auto parts store and he can get me a stock one for $116.00
or he can get me the z06 85mm for $63.00
so with the connector the total is till gonna be less than 100 bucks
with that information and i have the hp tuners program.....
would you guys still do a stock one or go the the z06?
Old Dec 7, 2009 | 11:39 AM
69LT1Bird's Avatar
Just put the Z06 in if you can tune it yourself, don't forget, you also need more intake parts to get the 85mm to the TB and to the duct going to the air filter.
Old Dec 7, 2009 | 03:22 PM
getsum27's Avatar
yeah i almost forgot about that........
im gonna take my air filter with me
if it wont fit the z06 meter im just gonna get the stock one if it does than ill be ok
thanks for all the input guys
Old Dec 7, 2009 | 03:28 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I have a takeoff stock MAF you could have for $60 shipped, paypal.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
