How much grout to put in my 6.0 block
Old Dec 10, 2009 | 07:57 PM
exploder's Avatar
Default How much grout to put in my 6.0 block
I am building another 6.0 motor and I am going to have the block partially filled with hard block. What I am wondering is how much do I tell them to put in? I am also having them dowel the main caps in the block. How many do I need? 2 per cap or two per side? Also do I need to use a solid dowel or a roll pin type?
Old Dec 10, 2009 | 08:00 PM
rich Z's Avatar
I would past this in advanced engine tech.
Old Dec 11, 2009 | 09:55 AM
1CAMWNDR's Avatar
Have the block poured up to the bottom of the water pump ports. I did mine in my garage this way and it stays almost too cool. Usually 184°-195° with a stock thermostat. I drive it every day and it doesn't heat up a bit.
For main cap dowels I'd have them do one per side for each cap. Can't help you on what kind of dowel to use though.
Old Dec 11, 2009 | 08:01 PM
Brief Encounter's Avatar
You are going to want to go with a soils type dowel pin. This way you have to take less material out of both the main cap and block. If you want a good example, look at how a pontiac block is done.
Old Dec 11, 2009 | 10:25 PM
exploder's Avatar
Anybody else care to tell how much hard block they used.
Old Dec 13, 2009 | 07:58 PM
1CAMWNDR's Avatar
Not too many people have filled LS blocks that I have found. Other opinions may be hard to come by.
