pacesetter y pipe...
I don't have a dyno comparison between to two y-pipes. Something like that would need to be tested back to back on the same car, same day, etc. So far the new design seems to be working better than the old design and merge is quite a bit better. Definitely a nice improvement in that area.
You shouldn't have any clearance issues with them. Even on lowered cars, there is enough adjustability to allow you adjust the maximum ground clearance and keep the pipes off the underside of the car.
I'll see if I can get the new pics updated on the site. We have been trying to get our new site up so the current one hasn't gotten the attention that it needs.
Jon
In factory trim the Pacesetter Y rivals all others in ground clearance by the use of a squished portion of pipe under the drivers seat. It's also only two pieces, something that I can't stress enough if you aren't going to be welding it together as the more joints there are the more chances you have for leaks. And, it utilizes the oem hanger on the passenger side... not sure if that's important but I liked it.
Lots of us have gotten the best of both worlds (clearance and flow) by fabbing in a 4" flowmaster merge. I couldn't be any happier with mine.
Here's a review I did right after purchasing mine:
https://ls1tech.com/forums/generatio...er-y-pipe.html
And here's some pics of my Flowmaster merge on a Pacesetter OYR:
https://ls1tech.com/forums/generatio...-ory-pics.html
