A/C box removal question
Old Dec 26, 2009 | 11:52 PM
AutomagicLS1's Avatar
Default A/C box removal question
My a/c has never worked (electrical problem I think) so I removed it a long time ago. I want to take the a/c box out this winter but will I be able to keep my heat or is there any way? Sorry may be a dumb question
Old Dec 27, 2009 | 12:41 AM
bww3588's Avatar
you have to cut the evaporator box from the heater box. basically, cut and bfh everything on the engine compartment side of the firewall, and make a block off plate for it with holes for the heater hoses. not too hard.
Old Dec 31, 2009 | 04:39 PM
Does the motor have to be out to remove the box? Can it be done witih just the heads off or perhaps somehow with the heads on lol
Old Dec 31, 2009 | 06:43 PM
nemss1's Avatar
Yes u can keep the heat. Just cut the box the juts out into the engine bay, remove the evaporator, and either make an a/c delete plate or buy one pre-fabbed. BMR sells one. I did mine heads still intact and motor still in the car. All I removed was the PCM for a lil more room
