00 ls1
Old Jan 1, 2010 | 11:23 PM
Chevellecamino69's Avatar
Default 00 ls1
ima bolt on a new harmonic pulley but was wondering if i should replace the oil pumpwhile im at it i hear some early ls pumps went out should i swap it befor i drop my engine in
Old Jan 3, 2010 | 12:17 PM
dgcustomz's Avatar
You should swap it out now before you drop it in and have problems later on. Will save you a headache later. Go shimmed and ported ls6.
Old Jan 3, 2010 | 03:27 PM
teke184's Avatar
if you have the $$$....it can't hurt.
better safe than sorry
Old Jan 5, 2010 | 04:27 PM
thanks i will swap it out is the slp oil pump any good
Old Jan 6, 2010 | 01:33 AM
f-bodyguy's Avatar
never hurts be carefull with the oring
Old Jan 6, 2010 | 06:50 AM
Brandon35thSS's Avatar
how many miles on your car?
Old Jan 6, 2010 | 09:35 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Hit scoggin dickey for the LS6 pump.
Old Jan 6, 2010 | 01:02 PM
bww3588's Avatar
may as well do the timing chain while your in there.
 Michael S. Palmer
Old Jan 6, 2010 | 01:05 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
also your oil pressure will change depending on what pump you run.
