Missing crank bolt!
Old Dec 20, 2003 | 06:14 PM
JDPZ28's Avatar
Default Missing crank bolt!
I installed my cam about 2 weeks ago. Well today I went to put on my
new ASP pulley. Put the car up on the lift and went to put on the pulley remover and there was no bolt holding the stock pulley on
I guess I got lucky that the pulley didn't come off. I later realized that
when I did the cam swap and put the stock pulley back on that I didn't
use locktite . What kind of damage could have happened had the pulley
come off?
Old Dec 20, 2003 | 06:46 PM
TWISTA TA's Avatar
WARNING: BAD TRADER STATUS
ALOT OF DAMAGE!!!!!!! Dent in the hood, ruined radiator, cracked block, brocken fan, ect....
Old Dec 20, 2003 | 08:06 PM
jrp's Avatar
jrp
SN95 Director
when you put the stock pulley back on you did use a NEW bolt didnt you? i used a new bolt and only tq'd it down to like 200ft-lbs of tq and it never loosened up.
Old Dec 20, 2003 | 08:47 PM
JDPZ28's Avatar
yeah I did use a new bolt and tightened it down pretty
good with my big 240lb butt pushing on the breaker bar.
But like I said I didn't use locktite and somehow it came loose?
Old Dec 21, 2003 | 03:34 AM
2002SilverWS-6's Avatar
You shouldn't have to use loctite if you used a new torque to yield bolt.
Old Dec 21, 2003 | 08:10 AM
boomcase's Avatar
Ditto , what they all said . Are you sure you put the bolt in.
Old Dec 21, 2003 | 08:14 AM
2001 Pewter WS6's Avatar
Restricted User
That is weird, I always have a hard time getting my bolt broke back loose with a 3' breaker bar...
Old Dec 21, 2003 | 07:05 PM
JDPZ28's Avatar
I'm positive I put it in.It was a new GM bolt, I remember taking it out of the bag. This time I used locktite on my new ARP bolt.
 Michael S. Palmer
Old Dec 21, 2003 | 07:08 PM
jrp's Avatar
jrp
SN95 Director
new gm bolts already have a form of locktite on them :dunno:, all the tq to yield bolts do. hope you have better luck with the arp bolt.
Old Dec 21, 2003 | 07:33 PM
DaleMX's Avatar
The pulley must have been bound up somehow then strightened out when you ran it causing you to loose torque on the bolt.
