Exhaust Leak
Old Jan 22, 2010 | 10:36 PM
Greekey's Avatar
Default Exhaust Leak
Is it possible the hear an exhaust leak from inside the car? Every time I give my car gas I get a weird sound from underneath the front passenger floorboard.
Old Jan 22, 2010 | 11:13 PM
InsaneDomestics's Avatar
Yes You Can Hear An Exhaust Leak From Inside The Car But That Doesn't Necessarily Mean That's What Your Hearing... But It Could Be. Your Gonna Have To Explain "Wierd Sound" A Little Bit Better
Old Jan 22, 2010 | 11:17 PM
Greekey's Avatar
When the car is parked and I give it gas, I hear the noise. Even when im moving it does it. When I get to higher rpms, the noise get louder. It sounds like air trying to exit something with limited space to do so. Almost like a whistling noise, but a much deeper tone. It its comming from under the floor board, right where my pipe is at.
Old Jan 23, 2010 | 12:35 AM
Crawl Underneath Your Car And Check All The Exhaust Connections And Make Sure They Are Tight And Look For Any Holes. That's The Best Advice I Can Give Ya.
Old Jan 23, 2010 | 01:27 AM
Ironxcross's Avatar
Check your collectors, I had issue with this a while back.
