could it be o2's?
Old Feb 5, 2010 | 02:22 AM
Mint02CETA's Avatar
Default could it be o2's?
Car runs smooth in open loop but as soon as closed loop comes around, it hesitates off its ***. cant accellerate unless its floored, and it randomly runs fine for a few secs then goes back to crap. :/. Could it be the 02's going out? if so, can i disconnect the front o2's and run it? ive read some posts saying yes, i just want to be sure. any help is appreciated, i dont get paid til the 15th and i dont wanna keep driving it with the misfire.
Old Feb 5, 2010 | 07:14 AM
teke184's Avatar
sounds like 02 to me...could also try cleaning your maf
Old Feb 5, 2010 | 09:00 AM
Mint02CETA's Avatar
The MAF seems fine. I cleaned it this morning and when i took my nephew to school it did the same **** as always. I think ima disconnect the o2's and see what it does then. if it runs fine then i know its them i guess?
Old Feb 5, 2010 | 09:17 AM
teke184's Avatar
no codes?
Old Feb 5, 2010 | 09:23 AM
99screamindemon's Avatar
i do not think you can run worth a **** with out your front o2's so i would not recommend disconnecting them!
WizardofDetailing's Avatar
Originally Posted by teke184
no codes?
Your car needs the front 02's to run properly. You can run it without the rear 02's but it will still throw an SES light. Do not run your car without the fronts. Are you throwing any codes??
Old Feb 5, 2010 | 11:20 AM
Mint02CETA's Avatar
i ran the obd on it last week and i had a random multiple misfire, o2 sensor heater circuit below operating temp, a few codes for the air! system being disconnected, and a coolant low temp reading but i had forgotten to reconnect the plug so that one went away. and if i ran with no o2's for a couple days after my header install and it ran pretty good...? i would figure the computer has to have some sorta safe mode in case the o2s go out that the engine can run on a base set air fuel reading maybe? just throwing that out there... your guess is as good as mine lol
