quick TB question.
Old Feb 6, 2010 | 09:54 AM
ssdungeon's Avatar
Default quick TB question.
I have just got a fast 90 for my Z. will the GTO drive by wire 90MM tb work on our cars? Also will the TP sensor work on that 90MM TB?
I think some years of the GTO fit if someone can give me the range of years that the 90MM TB that works with the fast 90 on our LS1 camaros would be great!!
Or will all Drive by wire TBs work?
Second question is should i get a 85 or 90MM MAF I see both sizes posted on the stock GTO parts section.
Thanks in advance!!
Old Feb 6, 2010 | 10:08 AM
MonmouthCtyLS7's Avatar
I think you need a 4 bolt tb for the fast 90's....The LS1 GTO is a 3 bolt I believe. Your question is a little confusing, I believe only the 6.0 GTO's got the 90mm and it was electronic.
