Need info on throttle bodys
Old Feb 9, 2010 | 12:51 PM
1 task's Avatar
Default Need info on throttle bodys
I have no idea about throttle bodys and need some insight here. I need to know what the normal stock TB on a 2000 Trans Am would be, and since i added the LS6 intake manifold, whats the larges size TB i could fit on it. Any info would be great since i cant find a link to teach me about it.
Thanks
Old Feb 9, 2010 | 12:55 PM
teke184's Avatar
stock is 75mm
stock inlet on the ls6 is 75mm..actually it may be 78mm...don't recall.
basically there really is no reason to go bigger on the TB...just port it and be done with it.
if you want to go bigger...go FAST 92
Old Feb 9, 2010 | 05:54 PM
MonmouthCtyLS7's Avatar
75mm stock. W/ the LS6 intake either run a ported stocker or a 80/85mm aftermarket TB.
