SLP LS6 EGR Manifold
Old Feb 12, 2010 | 05:12 PM
99huggerorangeZ's Avatar
Default SLP LS6 EGR Manifold
does anyone know if the slp ls6 egr manifold will fit over the ls1 coolant cross-over pipe? or will the base need to be modified or replace the lines with the ls6 version?
Old Feb 12, 2010 | 06:20 PM
garygnu's Avatar
the ribs on the bottom of the intake can be removed using a dremil tool and cutting bits.
Old Feb 12, 2010 | 06:47 PM
1sicss's Avatar
or a chisel, if you do get one with the coolant block offs it better to leave the crossover pipes and modify the base of the intake so that u can prevent detonation in the 7th cylinder.
