O2 simms Question???...
Old Dec 26, 2003 | 07:02 PM
99ramairguy's Avatar
Default O2 simms Question???...
I am not sure but I am putting on LT headers and an Off road y pipe. So with that I know i need the O2 simms. The simms might get here after the installation date so will the car be fine without the simms? Or do i need the simms on there for the car to be ok?
Thanks,
Mike
Old Dec 26, 2003 | 09:31 PM
jrp's Avatar
jrp
SN95 Director
yes the car will be fine w/o them you'll just have an SES light.
Old Dec 26, 2003 | 09:55 PM
Tally TransAm's Avatar
what he said
Old Dec 27, 2003 | 12:14 AM
The SES light is just the check engine light right? Or is it a different light, because you have to have ls1 edit to get the check engine light off right?
Old Dec 27, 2003 | 12:28 AM
dropkick's Avatar
Default PCM Codes
You will throw codes p0140 (driver's side) and p0160 (passenger side). The description for the codes is "no activity on bank 1 sensor #2 and bank 2 sensor #2". These codes won't affect performance. Just be sure to reset your PCM after you install your O2 simms.
Old Dec 27, 2003 | 12:32 AM
dropkick's Avatar
For instructions on how to reset your PCM (clear the SES light) go here:
http://www.ls1.com/link_ecm.html
Old Dec 27, 2003 | 12:57 PM
Thank you
