Mounting Gauges
Old Feb 16, 2010 | 10:38 PM
Greekey's Avatar
Default Mounting Gauges
Guys whats the best way to bring in electrical wires inside from the engine bay on the drivers side? I know about the grommet on the passenger side. Anywhere where I can drill? Or is there a grommet?
Old Feb 18, 2010 | 08:59 AM
krissoto's Avatar
I drilled mine because I have 3 guages and a nitrous line to run in the car. I drilled from the inside. I drilled a small pilot hole, ran a wire outside and went from there. Trial and error. Then I took an old piece of my tranny dipstick and cut it down and threw a piece of rubber hose on each side. Its tight and wont have to worry about any binding trying to shove anything thru. But whatever you go with just make sure you have some sort of insulation around whatever you put thru there.
