LS7 injectors
Old Feb 17, 2010 | 06:43 AM
t72ss402's Avatar
Default LS7 injectors
Who sells the mounting kit that allows you to install these injectors onto a LS1/LS6 style manifold. I already have the pig tails for the wiring harness.
Thanks Tim.
Old Feb 17, 2010 | 06:47 AM
the_merv's Avatar
Veteran: Air Force
Are they similar to the LS2 Injectors?
Old Feb 17, 2010 | 12:23 PM
t72ss402's Avatar
I beleave they are a little shorter.
Old Feb 17, 2010 | 01:06 PM
the_merv's Avatar
Veteran: Air Force
The reason I ask is I have LS2 Injectors, and all I had to do was shim my Fuel Rails up 1/2" inch, everything works fine.
Old Feb 17, 2010 | 08:28 PM
t72ss402's Avatar
Thanks for the info. you said you had to raise your fuel rails? I am planning on running a typhoon 96mm intake. Would this matter?
Old Feb 18, 2010 | 06:48 AM
the_merv's Avatar
Veteran: Air Force
Is it made to use stock Fuel Rails?
Old Feb 18, 2010 | 07:03 PM
t72ss402's Avatar
Yes the typhoon is made to except LS1/LS6 style injectors, or you can get the one that will fit an LS2 intake.
