problem with cable to throttle body need help!
Old Feb 18, 2010 | 10:32 PM
stevez2885's Avatar
Default problem with cable to throttle body need help!
ok installed my new weiand intake manifold and bbk tb and the throttle cable reaches and idles fine but the cable that is next to it (my cars an a4) when i hook the cable up with a red ring around it it idles way to high. is there any way to adjust the red cable to reach out farther so that it will idle fine?
Old Feb 18, 2010 | 11:43 PM
slayerized6's Avatar
follow the black cable and youll see a box on the cable. remove the black cap and adjust the cable accordingly. and while holding the cable out/in depending on how you want to adjust the throttle cable, put the cap back on
