Just installed FLP LT
Old Dec 27, 2003 | 05:50 PM
1STGEN68-2000SS's Avatar
Default Just installed FLP LT
Just finished installing the headers. Took about 4 1/2 hours on a rack and they slid right in, no grinding or steering shaft removal, had to remove about 4 inches of the I pipe and replaced the plugs at the same time.I ordered the set for a 2000 SS with egr and ended up removing all the egr system and blocked of the plates, With the extended warrenty if I need to I will put it back on.Sounds great .
Alan
Old Dec 27, 2003 | 07:38 PM
Deech's Avatar
PR Director
How does the y-pipe fit? Does it bang the floor board? They had problem with their y-pipes banging and wanted to know if they have fixed the problem. Also how low does the y-pipe hang. Do you have pics of the headers installed? I am considering these headers and thats why I am asking these questions. Thanks for you help.
Old Dec 27, 2003 | 08:23 PM
We left off that thin brace under the y pipe off and I was told that everybody else does also. The lowest part of the pipes is the left cat, ground clearence with eibach pro springs is 4 inches ouch!. but the installation went as smooth as silk
Good luck
Alan
Old Dec 27, 2003 | 08:40 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Alan
4" isn't bad at all. Stock clearance is only about 4.25" at the lowest part of the left side stock Y-pipe. I measured mine before I put the headers on. My current setup give me only 3.25" and that's been just fine. I never hit anything with it....
Old Dec 27, 2003 | 09:15 PM
That's good to know it took me longer to get the car off the rack than it did to install the headers
Alan
Old Dec 27, 2003 | 10:33 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Sounds like you guys had it easy.....here's my fiasco
http://www.geocities.com/y2k_ta/smr0...erinstall.html
Old Dec 28, 2003 | 04:24 PM
ChevyWeatherman's Avatar
master of the "jack"stand
My FLP install was identical to yours...easy!!
