I cant leave well enough alone
Old Feb 24, 2010 | 08:46 AM
puggerton03's Avatar
Default I cant leave well enough alone
i have a loudmouth on my car. i got a magnaflow bullet to replace the resonator. well the elbow that curves up to go over the axle has to be opened up so the new bullet will slide into it. well, the elbow wouldnt come out so i had to take a cut-off wheel and cut about 3 slits in the outside pipe and then pry apart the outside pipe, the one that is the main peice that runs out the back. i finally got it apart but i think i might have messed it up. im going take it all to a muffler shop and see if it can be fixed. this sucks. i hope the new sound is worth all this hassle. and its winter here so i cant take it anywhere.
Old Feb 24, 2010 | 09:19 AM
MonmouthCtyLS7's Avatar
Not sure if your looking for a reply or just venting...either way good luck.
Old Feb 24, 2010 | 09:24 AM
trippinholyman's Avatar
I bottomed out once on the way to school with my LM and that night I just took a BFH and some large pliers and opened it up. It shouldn't be a big deal, and I was using the old exhaust clamps. If you think it will leak, get some of the bigger exhaust band clamps.
You just have to make sure that it slips on all the way (the slotted part of the pipe is completely covered by the other pipe) and you torque it down enough to crush the pipe enough so that it seals.
I didn't think about cutting the slots when I had to fix it. Good thinking. Like I said, I just pounded on that thing with a pair of pliers and a BFH.
Old Feb 24, 2010 | 09:47 AM
i hope i can save it. id rather buy some konis rather than a new catback.
Old Feb 24, 2010 | 09:52 AM
01ssreda4's Avatar
Dynamax sells just an over the axle pipe I believe. No reason an entire catback would have to be replaced.
