RevXtreme Catch Can installation issue
Old Mar 6, 2010 | 05:38 PM
chon79's Avatar
Default RevXtreme Catch Can installation issue
So I got my catch can and started the install today. Are these the new designs of their catch cans? See the pic below. The nipples are on top, where most I have seen it where there is a valve on the side of the catch can.
And since I am doing the breather oil cap on the car, can I do away with the pcv valve also below?
Old Mar 6, 2010 | 11:47 PM
cowboysfan's Avatar
looks about right.... I wouldn't delete the pcv valve just incase you have a backfire....
Old Mar 8, 2010 | 12:38 PM
chon79's Avatar
Which would be the inlet and outlet?
Old Mar 8, 2010 | 04:25 PM
TooLateVTEC's Avatar
That 90 on the top should be the INLET
Old Apr 14, 2010 | 07:41 AM
6']['9's Avatar
did you get it installed yet?
Old Apr 14, 2010 | 08:25 AM
JasonSS2000's Avatar
Not w/the RevX can. The center is the inlet. I would get another 90 to put on the center as well and it runs to your tubing from the valve covers (or the valley cover if a LS6/2/3) and the outlet goes to the vac nipple on your intake manifold.
Old Apr 14, 2010 | 09:16 AM
99_SS_LS1's Avatar
I used the breather with my rev extreme can, until I realized how much unmetered air it was letting in. My fuel trims were all out of whack. I wouldn't recommend it, and don't understand why they don't explain that before selling the parts?
Old Apr 20, 2010 | 06:08 PM
99_SS_LS1's Avatar
No responses?
