Jet hot cats should I yank em out?
Old Dec 30, 2003 | 07:51 PM
Humanoid's Avatar
Default Jet hot cats should I yank em out?
I am bringing my car in on Friday to MTI to get heads/cam and a few more boltons.
I have Jet hot headers, Jet hot catted y and Loudmouth.
Do you think the cats will hurt my dyno numbers much?
How do they flow?
If I pull them I will have to put in the dynomax muffler in place of my resonator on the LM at a later date. It is loud now and I love the sound. I cant imagine it any louder... BUT....HP & TORQUE is MY NUMBER 1 PRIORITY. If the dif is only say 5 hp i guess I will leave them in but more than that and they have to say bye bye.
Old Dec 30, 2003 | 07:54 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I would say to remove them, but that is also because I am anti-cat. I think the exhaust note is far more appealing without cats, using the proper mufflers to rid youself of rasp and un-tuned exhaust note. Cats give any system too "mellow" of a note, IMO.
Also, cams don't sound as nice (less lope) through cats.
Old Dec 30, 2003 | 07:55 PM
Darkhalf's Avatar
They are a PITA to get out!!! I'd just leave them on to see how much you actually dyno.
Old Dec 30, 2003 | 09:07 PM
Humanoid's Avatar
Understand on the PITA part. The tolerences are so close between the sleeve they fit in and the cat that I put a bit of silicone lube on them just to get them to slide in when they were new. I imagine they are pretty siezed up by now.
Old Dec 31, 2003 | 01:54 PM
Darkhalf's Avatar
I also had the two little cut pieces mounted in the ypipe when I took the cats off, decided I didn't like the sound. So after 2 days of driving the car maybe 30 miles tops I wanted to take them off, well those two little bypass pieces are in a land fill somewhere because I literally had to beat the crap out of them to get them out. They were all mangled and bent up, so they were essentially useless
