harmonic balancer - is mine in too far?
Engine is a 2000 Corvette LS1. The alternator bracket is from a fourth gen fbody (mentioning this in case it matters).
Is this normal? The reason I ask is because I thought the belt should be "in line" with all the pulleys and the crank. The alternator pulley and the alternator bracket pulley look like they stick out farther than the harmonic balancer.
Do I need to get a harmonic balancer puller and pull it out some??
You can not put the balance on too far.
I'll hunt down an fbody one today and that should line everything up. Thanks again for the info, I appreciate it!
