Blinking SES after header install
Old Dec 31, 2003 | 06:52 PM
ShadowLightCSU's Avatar
Default Blinking SES after header install
I just got done installing my pace setters, things went pretty well. Don't have one bolt on the EGR, that's one item. Then secondly, the y-pipe is a POS, I couldn't get it to fit with the Loudmouth. So I left it off and was planning on going to an exhaust shop to get a professional opinion. Possibly shorten the y-pipe or the loudmouth. The problem is that it just doesn't want to slide on to the header, the angles look all messed up. I got it all on, I went to head home for the night, and about 30 seconds later the SES is blinking. I know not having any pipes after the y isn't good,but I didn't think that was blinking SES material. Any thoughts? Maybe a wire isn't on right?
Old Dec 31, 2003 | 07:25 PM
Other things to mention, she fired right up, idles smooth. Only blinks when I give her about 1/3 throttle. Also when I step in to it, it briefly blinks the check gauges light.
Old Dec 31, 2003 | 08:26 PM
wild thing's Avatar
You are probely setting a code for the rear 02 sensors. with no back pressure they can't get a reading on the exhaust after the cat.
Old Dec 31, 2003 | 09:08 PM
SSTYCOON's Avatar
You might be right about the wire, I thought the blinking SES light was for a misfire, look in the owners manual for the blinking SES light. It's easy for a wire to be disconnected or ruined after a header install
I run LT's, and a Muffler right off A ORP and No SES light. even if the light was on because of the set up , it wouldn't blink
Old Jan 1, 2004 | 07:07 PM
For those of you in the future which may be searching for misfire information, I got it figured out. It was a misfiring situation. I didn't have very good connections on the plugs. When I connected the y-pipe the exhaust tips were shaking it was misfiring so bad.
Old Jan 1, 2004 | 07:56 PM
foff667's Avatar
LS1TECH Sponsor
you just have the best luck dont you with that header install lol mines gone pretty smooth and the sound kicks ***.
lata
Bill
Old Jan 2, 2004 | 01:28 AM
Sure am This vibration is totally awesome too. I didn't grind the k-member and it's shaking the whole damn driver's side.
