HVAC Vaccum Question
Old Mar 16, 2010 | 03:22 AM
DGageSS's Avatar
Default HVAC Vaccum Question
on the back of the intake manifold, the one opposite of the brake booster hose. i know its for HVAC but i had a question. I deleted the ERG and AIR systems. since i did that should i just connect the fitting that comes out of the harness wires. Seeing as the other lines went to what i believe was the air system. putting in a 408 and forgot how this came apart. thanks
Old Mar 16, 2010 | 04:31 AM
Predator's Avatar
If I understand your question just cap the AIR connection on the back of the intake. Napa sells these little red caps for that purpose.
Old Mar 16, 2010 | 05:53 AM
DGageSS's Avatar
figure that was it thanks for the help.
Old Mar 16, 2010 | 06:10 AM
Predator's Avatar
I didn't mention, figured you knew, that you connect the HVAC to one of the outlets behind the intake and cap the other one for the AIR system.
