Spark plugs Loosening up
Old Mar 16, 2010 | 09:33 AM
svg210's Avatar
Default Spark plugs Loosening up
hey guys, I need some help.
I have NGK Tr55's, when I first tightened them I followed the instructions from the box, and I've had 3 plugs all from the driver's side head that have loosened up over these past few months. Now, I keep re tightened them but they seem loose up after a couple of weeks. any one have any input? it would be appreciated
TIA
Old Mar 16, 2010 | 11:04 AM
Jontall's Avatar
Remove the plugs and chase the treads in the head carefully (put grease on the chase to pick up metal particles). Apply anti-seize to the spark plug threads and re-install.
Old Mar 16, 2010 | 12:10 PM
Z28_LT1's Avatar
be very careful about the chase. these threads are really important so make sure you do it right. not saying you cant do it, just saying be careful so you don't have more problems after you're done.
Old Mar 27, 2010 | 03:41 PM
svg210's Avatar
Thank you guys, but I might use this as an excuse to go H&C!
I got to be careful though because one good compression stroke, can blow number 1 right out, If I dont check it often.
