I need one more like this...
Old Mar 17, 2010 | 07:24 PM
salemetro's Avatar
Default I need one more like this...
Anybody know where I can find one more of these? GM has, in it's wisdom, "superceded" the original 12604711 part number. Ughh!!!!
Old Mar 17, 2010 | 07:36 PM
DaddySS's Avatar
Why can't you use the superceded number?
Old Mar 17, 2010 | 08:16 PM
blue98Z's Avatar
Just use the LS6 version
Old Mar 17, 2010 | 10:57 PM
SweetS10V8's Avatar
Superceded just means it was given an updated part number, get the new one then.
Or did you mean "obsoleted"??
I also agree, just get the LS6 version
Old Mar 17, 2010 | 11:45 PM
salemetro's Avatar
No, the local GM dealership ordered the old part number, but was sent a kit that is like most others, in that it just has the front crossover and block-offs for the rear steam ports. Any Idea what the part numbers are for the LS6 version?
Old Mar 18, 2010 | 12:30 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Looks like the original part number has been replaced by what you got, the LS6 kit which has just a front pipe and plugs for the rear. Order another kit and put it on the rear. You'll need to lengthen the hose for the rear set and put the two hoses together with a T fitting.
It looks like you can order just the pipe without the plugs as part number 12602544.
http://www.shopfbparts.com/servlet/Detail?no=210
Old Mar 18, 2010 | 01:21 AM
salemetro's Avatar
Hence, my search for the original style. I have one on my 5.3 build, and wanted to use one on my 408 build.....they just look so much cleaner than 2 crossovers linked together with rubber hose ran all over the place. Thanks for the help though...I'll just have to keep my eyes open.
Old Mar 18, 2010 | 08:08 AM
bww3588's Avatar
i dont see the problem. you dont have to connect the 2 cross overs. you dont even need the rear crossover. just the front and the 2 plugs in the back and your done.
Old Mar 18, 2010 | 10:53 AM
thunderstruck's Avatar
i have one hanging in my garage
