autometer gauges ?
Old Jan 1, 2004 | 04:31 PM
1RawTA's Avatar
Default autometer gauges ?
Im ordering some gauges tommorw, i was going to get water temp and a/f ratio but i have heard the stories that the a/f doesnt work that well. waht do u guys think? and if not those 2 gauges wich other ones should i get
Old Jan 1, 2004 | 04:43 PM
oldfart's Avatar
Personally if I had to pick 2 gauges to get I would select a fuel pressure and oil pressure gauge. Those 2 are much more important than Water temp and a/f ratio. The a/f ratio gauge is a nice piece and reads very accurate....but since it ties into the O2 sensor it is no more accurate than the O2 signal...which we all know is a 'best guess' situation. And while the factory water temp gauge is not very accurate you don't really need to worry about it unless you are overheating.
My advice is to go with the fuel pressure and oil pressure.
Old Jan 1, 2004 | 06:22 PM
1RawTA's Avatar
are the guages easy to install? and does anyone have any site that has direction on how to ?
Old Jan 8, 2004 | 02:09 AM
JCorc5150's Avatar
fuel press gauges arn't cheap... Close to $200, but good to have... I just ordered a electric ultra lite.....
Old Jan 8, 2004 | 07:33 AM
Slowhawk's Avatar
LS1Tech Sponsor
I run Phantoms Autometer's in my GN.Electris fuel pressure and oil pressure.Both work good.
On my TA I run Cyberdyne Fuel and Water.They work great and I love the digital readout(easy to read at a glance)The fuel pressure gauge was under $100 with sender!!
The autometer A/F gauge is a complete waste of $$..I run a gauge that reads voltage from www.speedshop.org and it works better.
Old Jan 8, 2004 | 03:22 PM
MONGOOSEWS7's Avatar
i would have to agree on the fuel pressure/ oil pressure.stay away from the air/fuel ratio gauge. why not go with a tripple gauge pod cluster and depending on what series of autometers you like go with water temp, oil press, and fuel press. those to me are three very important guages. i like the cobalt c2 gauges. they may be a little more pricey but they look so sweet lit up at night. they have a bright cobalt blue glow and kick a$$. i think this will help ya. www.autometer.com
Old Jan 8, 2004 | 07:24 PM
cm02WS6's Avatar
Get a boost gauge!
Joking aside, I think the carbon fiber gauges would look pretty good.
Old Jan 8, 2004 | 07:35 PM
Ferocity02's Avatar
I'd suggest water temp above all, you stock gauge is a dummy gauge, useless. The A/F gauge is nothing but a light show, but it can show some large differences in the A/F ratio, and it only works at full throttle. I'd go with oil pressure, or tranny temp. I will help you with the install if you get these. If you get water temp, you need the M16x1.5 adapter to put the sender in the block right above the starter, or you can try to get it in the block by the #8 cylinder, but good luck....
 Michael S. Palmer
Old Jan 8, 2004 | 07:36 PM
CLB3RD's Avatar
the gauges u get depend on what u need to monitor lol...im getting a cobalt a/f and tranny temp!!
Old Jan 8, 2004 | 09:16 PM
1RawTA's Avatar
yea i orderd the oil pressure, and a/f ratio for now.. im gunna order the water temp when i order the gaskets for my new headers i just picked up.. when i get them maybe u can tell me how to do the install
1RawTA's Avatar
Originally Posted by WS6FirebirdTA00
i have a/f and coolant temp. yes the a/f is accurate just have to get the right o2 numbers for it, the ones they give u arent right. but yes it stays very consistent
do u have the right numbers that you can give me ?
Old Jan 8, 2004 | 09:37 PM
Ferocity02's Avatar
A/F ratio....lol, you will find yourself replacing it soon, even if it means buying N20 so you can put in a gauge to replace it
I only know how to install the water temp, A/F ratio, and tranny temp gauges. PM me or e-mail me anytime.
Old Jan 9, 2004 | 03:20 PM
Biochem's Avatar
I got the Cobalt gauges... A/F and fuel pressure. The A/F bounces around a lot and the FP gauge just sits at 60psi, so it's rather boreing. lol
Old Jan 9, 2004 | 04:36 PM
Alucard's Avatar
when you nail it your FP should drop a few PSI, thats exciting sometimes
Brandon (owner of Cobalt A/F, FP, TT gauges)
Old Jan 9, 2004 | 05:50 PM
Got Me SOM's Avatar
Definitely oil pressure.
Gauges are just for looks anyway, get whatever ya want
Old Jan 9, 2004 | 06:12 PM
WS6FirebirdTA00's Avatar
hell i got my gauges for reasons. true they are a lot for looks but if your gonna get em get something you will actually want/need to read
Old Feb 1, 2004 | 07:02 PM
FenixSS's Avatar
Does it matter if your car is M6 or A4? Do the gauges come with install instructions? I've got a 3 pod for my T-top from Autometer. I'm leaning towards the Cobolt ones, but can't decide.
From this post it seems that the most popular are the OIL PRESSURE, FUEL PRESSURE, WATER TEMP, and TRAN TEMP. Something else that someone mentioned to me, a VACCUM GAUGE. Something about it reminds you to let off the gas to help you conserve gas? Any more thoughts on this? Not in a rush to buy/install, just to learn...for now
Old Feb 2, 2004 | 12:17 AM
JBIRD02's Avatar
I have the Cobalt A/F, and water temp. I got the A/F gauge just to get a basic idea of whether I'm running rich or lean at WOT, so it does its job for me, but like i said, I'm not looking for exact #'s. The water temp is cool I guess, it didnt work when i got it, so i had to send it back to get fixed.
Old Feb 2, 2004 | 03:08 AM
FenixSS's Avatar
So I guess it doesn't matter on A4 or M6? Anyone know what the vaccum gauge does other than what I previously posted?
Old Feb 2, 2004 | 07:53 AM
talkin about what gauges to get for an a4 or m6? it really doesnt matter unless on the a4 u have modded the trany and have a cooler and wanna keep an eye on temps i guess
