How many A/C compressor bolts?
The two on the bottom are longer than the two on the top.
The top ones are kind of a bitch to get to. I'm pretty sure I got to mine from up above, in the engine bay. I used a ratching box-end wrench (I think).
The compressor should be unbolted from the bracket and then there are four more bolts holding the bracket to the block that need to be removed in order to remove the bracket.
Hope this helps good luck.
