HELP! Poly. motor mounts winning battle!
Old Jan 2, 2004 | 07:48 PM
02 Silver Z's Avatar
Exclamation HELP! Poly. motor mounts winning the battle!
Can one of you fellas that have installed Poly. motor mounts give me some tips? I am in the process of installing these Prothane mounts and when I attempt to install one of the through-bolts, it throws the other side way off. I`ve been trying to get one side in (through-bolt) and then stick a pry bar between the cross member stand-off bracket and the clam shell and try to force it to line up but with no luck. I`m also doing it by myself, which doesn`t help. Any help with this would be great. Thanks.
Old Jan 2, 2004 | 08:08 PM
Just to make me seem that much more pathetic, I have the heads off the car so I can ,for the most part, get right at them.
Old Jan 2, 2004 | 08:33 PM
chino_man279's Avatar
When I replaced my passenger side mount, I started the bolt in from the front side of the motor. After I got it started, I used a floor jack on the transmission to get the back side hole to line up to the correct height. Then I used a scrap piece of 2X4 and pryed the motor over from the wheel well. When I got the hole lined up I jammed a center punch in through the hole to hold it there. Then I rammed the bolt all the way through to finish up the install.
Just try to use the jack to raise and lower the motor to the right height first.
Joe
Old Jan 2, 2004 | 08:34 PM
WILWAXU's Avatar
Good set of instructions here:
https://ls1tech.com/forums/generation-iii-external-engine/99615-poly-motor-mounts.html
Old Jan 2, 2004 | 09:42 PM
That`s the write up I`ve used for the install. He did his @ two different times. First the drivers side and then the pass. later. I wonder if he had the same problem?
Old Jan 2, 2004 | 10:42 PM
WS6FirebirdTA00's Avatar
took me a long *** 6 hrs of h ell doing mine, nothing ligned up right, just get a few people to move the motor and wiggle the bolts in, get the ones in the block first cause thats aluminum u dont wanna cross that. then work on gettin them in the kmember
