thermostat help
Old Mar 26, 2010 | 12:16 PM
shepss217's Avatar
Default thermostat help
well i'm getting ready to buy a lower temp thermostat since my car seems to ping when its hot outside and i only run 93 octane, can i swap a new 160 thermostat onto my old housing without having to buy a new housing too? if so let me know, thanks
Old Mar 26, 2010 | 12:56 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Most of the ones that the sponsors have come with the housing for around $50
Old Mar 26, 2010 | 05:08 PM
Mumbles's Avatar
What kind of car and has the water pump ever been replaced?
If you have an F-body and it has the original water pump, you will need this Thermostat that has the stat and housing as one piece.
http://www.slponline.com/view_product.asp?P=100223
If you have a newer water pump and/or a newer Corvette, you will need just the thermostat and you can reuse the housing that you currently have.
http://www.sdpc2000.com/details/scog...enter/sd105160
