Power steering pump delete
Old Mar 26, 2010 | 01:09 PM
cbr600rx7's Avatar
Default Power steering pump delete
Will deleting the power steering pump effect the brakes in any way shape or form on a LS1 F-body.
Old Mar 26, 2010 | 02:51 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
No it won't
The pump has nothing to do with the brakes
Old Mar 26, 2010 | 02:59 PM
cbr600rx7's Avatar
Didnt think so. Do you leave the cooler lines attached and just block off the supply that would run from the pump?
Old Mar 26, 2010 | 03:18 PM
twelver12's Avatar
No not at all they are two totally different systems
Just curious, why are you deleting power steering
Old Mar 26, 2010 | 04:03 PM
Z28/2002's Avatar
I removed the pump, bracket and lines. I cut the lines on the rack and left about 6 inches then I looped them together with a piece of hose
Old Mar 26, 2010 | 04:13 PM
Alt's Avatar
Alt
You can't just run a short belt to delete the PS?
Old Mar 26, 2010 | 07:17 PM
cbr600rx7's Avatar
Thanks for the info. And yes i found a thread earlier that showed the Part number for a shorter belt.
