ACCUSUMP in an F-Body
I wanted to put it where the air pump was behind the left front bumper. I was glad to see it would mount horizontal no problem. I want to use the 4 mounting holes front the air pump.
I found a scrap piece of aluminum that looked like it would work. I went to the shed to trace the hole pattern from the air pump.
I saw the double hole pattern and the vibration mounts so said what the heck. I used a small saw blade cutter in the dremel to make the rubber slot large enough.
I made some spacer out of a scrap of Delrin.
Anyone whose interested I thought the accusump itself was real well made.
The bummer part is I wanted to use the forward Oil galley plug. Some guy with a Vette said he did. Well there is not enough room behind are alternator! So I'm going to the remote filter route. At least there is enough room up near the accusump to put it in there as well.
Ed
I don't like the idea of a sandwich adapter as our oil filter is so low.
I ordered a remote filter adapter from canton. I was looking at the remote filter mounts and I came across the remote canister filter from canton. It was almost the same price as remote oil filter mount. Well I ordered all the SS braid hose and fittings. The price is a little steep. I'm around $700.00
but I suppose never having to say your sorry to your LS3 Stoker is priceless!
