BROKEN Header Bolt ....
Old Mar 27, 2017 | 12:40 PM
  #41
Forcefed86's Avatar
I get this is super old, but I see no mention of this method.
No need to remove the head. 2 minutes with a mig/tig welder and a nut and you can pull it out super easy. I hose it down with JB blaster first as well, then use a torch to clean it off. Place nut over broken bolt, and fill nut with weld. Remove with wrench.
  #42
samerickson89's Avatar
Originally Posted by Atrus_SS
Holy old thread....
I snapped the passenger side rearmost bolt last summer during my install. Really kick myself for it too, because I think it was a dumb error on my part.
Anyway, I discovered Dorman 917-142. It's a kickass clamp that is completely worth the $26 on Amazon. Very beefy design. Been working well for me!
Dorman also has another P/N that wraps around the side of the head - kind of a triangular piece that wraps around the back/front of the head if it's one of the end bolts that snapped. I used the one I listed on the rear side and it fit perfectly, so I see no need for the other design.
Does either P/N 917-142 or 917-107 fit an LS1? Neither of them say they do, but those are the only two I can find so I'm hoping one will work.
Old Mar 29, 2017 | 06:48 AM
  #43
Atrus_SS's Avatar
917-142 should - I have it on my '00 LS1. Passenger side rearmost bolt broke.
Old Mar 29, 2017 | 06:56 PM
  #44
Thanks, I'll give it a try!
Old Apr 16, 2017 | 11:44 AM
  #45
6t5elcamino's Avatar
It seems everyone who has worked on LS manifolds has this problem, including me. Two bolt heads were broken off in mine. They are out, drilled and used an easy out.
I see lots and lots of posts all over the place about how to get the bolts out. What I have been unable to determine is what is causing it. My assumption is that because the heads and manifold are different materials when they get hot they expand/contract at different rates, bolts bend back and forth with heat and cold........ eventually 'snap'.
So how can this be prevented so it doesn't happen again? Certainly you can buy the latest whiz bang, wazoo bolts at great expense, not sure they wouldn't do the same thing. I'm no scientist but to me all the bolt treatments in the world are gonna be subject to heat, therefor same issue. It seems even studs would have a similar fate.
So what to do to make it a solid dependable repair?
Old Apr 16, 2017 | 05:52 PM
  #46
Forcefed86's Avatar
They break because people over tighten them and stretch/weaken the bolt. Then add a ton of heat to the mix it it weakens it more.
Torque them to factory spec with a little anti seize on it for good measure. I've never had one break or leak after repairing.
Old Apr 16, 2017 | 06:10 PM
  #47
Hmmmmm, these particular ones were factory installed. Good to know that you haven't had repeat issues.
Old Apr 16, 2017 | 06:24 PM
  #48
Forcefed86's Avatar
Doesn't mean someone didn't over torque them. But yea, that shouldn't happen.
I pull my manifolds on and off yearly at minimum on the turbo engines I build. Never had an issue.
Old Apr 16, 2017 | 08:34 PM
  #49
wannafbody's Avatar
I doubt that the factory puts antisieze on any fbody bolt.
Old Apr 19, 2017 | 08:17 AM
  #50
JohnDaMan's Avatar
This is the best way to pull them out. Weld it and throw a torch on there to heat it up....it loosens the bolt some.
