Repeat Offender P0136
Old Apr 6, 2010 | 06:12 PM
gjohnson's Avatar
Default Repeat Offender P0136
Ok, I'm looking for a little help here. I keep getting the code above and I don't seem to be getting as good of gas mileage as I think I should. I've erased the code multiple times and it seems anytime I drive the car over a 10 min period of time the code will resurface. I've got new O2 sensors that I picked up for my swap a few months ago, the swap has only been running for a little over 2 months and the code has been an issue the entire time. Now, I only have the 2 front O2 sensors so should this be the driverside or passenger side. Also, I had to hardwire these sensors in, so could that be giving me this problem or would it cause both sensor to show errors?
Right now I'm getting about 17 mpg in the city with my swap and I drove my entire last tank without shifting over 3000 RPMs. From time to time the exhaust does seem to smell a little rich, but wouldn't I be throwing a code for that too?
Old Apr 7, 2010 | 11:24 AM
gjohnson's Avatar
Anyone. I just filled up again last night from this last tank of gas and shifting consisently at 2500 Rpms or less I got up to 20 mpg.
Old Apr 7, 2010 | 11:37 AM
Juicy J's Avatar
That is not bad city mileage at all. I dont see what the problem is?
Old Apr 7, 2010 | 11:47 AM
94'BLKBRD's Avatar
The code popping up is the problem.
Old Apr 7, 2010 | 12:03 PM
94'BLKBRD's Avatar
What are you using to delete the code? Handheld tuner, efilive, hp tuners?
Old Apr 7, 2010 | 12:37 PM
69LT1Bird's Avatar
Just because you clear a code doesn't mean the problem goes away.
Have you followed any diagnostics?
Try this site:
P0136
Old Apr 7, 2010 | 01:36 PM
gjohnson's Avatar
I'm using a Handheld scan tool to delete the code.
Thanks for the link, I will give that site a try.
Old Apr 7, 2010 | 03:02 PM
H8TO WRK's Avatar
What happened to the 2 rear o2 sensors? that code is pointing to Bank 1(Drivers side) Sensor 2(rear)
 Michael S. Palmer
Old Apr 7, 2010 | 03:13 PM
69LT1Bird's Avatar
Are you sure you spliced these into the correct wires or did you connect the new front O2's to the rear O2 wiring?
Old Apr 7, 2010 | 04:11 PM
94'BLKBRD's Avatar
Did you delete the cats and remove the rear O2's?
Old Apr 7, 2010 | 08:42 PM
gjohnson's Avatar
Yeah, I deleted the cats and removed the rear O2's. Crap. My rear O2 sensors were suppose to be tuned out. Does this mean that some how, when I pinned the harness that I connected the wires to the wrong pins or am I having a tunning issue. Also, why wouldn't the other rear O2 sensor throw a code too?
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
Old Apr 9, 2010 | 12:34 PM
gjohnson's Avatar
Can someone shed some more light on this for me?
Old Apr 9, 2010 | 03:23 PM
Formula1996's Avatar
It sounds like they weren't tuned out correctly. But if you have a handheld or software that can monitor the primaries I would do that just to make sure it looks like they are working correctly (that should tell you if you wired them correctly). You could also try pluggin in a rear o2 sim to see if it makes the problem go away.
