upgrading to ls6 intake
Old Apr 7, 2010 | 08:04 PM
TA98LS1's Avatar
Default upgrading to ls6 intake
will i be able to pass emissions sniff test after removing and deleting egr, car is 1998
Old Apr 7, 2010 | 09:17 PM
DCC!!'s Avatar
i would try to ask some people in the regonal section you might get a better answer from ppl who live in the same state
Old Apr 8, 2010 | 08:58 AM
Frost's Avatar
You probably want to get your tune adjusted though. The LS6 intake is much more efficient up top. The 98s have a lot of timing at WOT from the factory; much more than your engine needs after an intake swap to an ls6.
Just my 2cents
Old Apr 8, 2010 | 10:46 AM
BlackScreaminMachine's Avatar
Internet Mechanic
As long as you do not have a strict Visual Inspection Process. I see no Issues. If stock, your fine. Tuning should def be done as it will make the car better.
