engine/trans removal questions....
Moderators- I didn't know where this went, move it if you need to.....
Thanks, Shawn
Gary
as for the motor, i'm not sure about accessories like a/c and what not, but you could get the motor itself out by just yanking the intake/fuel rails/coil packs, etc and leave the everything else including valve covers I imagine. best place to put the chain is in the heads anyway. if the exhaust manfolds are stock could prolly leave those,too..
I'd pull the water pump though to be safe and of course the radiator, condensor if you have it, etc. but pulley and what not should clear ok.
